1 - 7 of 7 Posts
Design Build
I thought I should have this.........................
.................and so I shall. Thursday.
It will come in handy for my expanded as-built service. I'll post a review by the weekend.
Use it a lot while its under warranty
Takes 6 weeks after sending it in for repair to get it back, should not take that long since I dont even think they open the box
I had one which rarely worked, battery drained quick and always had connection issues. Customer service was useless
That was 4 years ago hopefully you have better luck
Design Build
I read the battery lasts only about one hour. That’s not too bad for such a small battery.
i’ve been known to buy tools that turn out to be failures. I like to do my own reviews so fingers are crossed.
Reactions: rrk
Keep us posted, I have had my eye on that. What a game changer if it works for scanning walls on estimates. Give you a good idea of what has to be moved before you open them up.
Design Build
Well, on the screen of the phone, it has a temperature range scale displayed. It shows the hottest to coldest things it "sees".
Design Build
The FLIR One comes with an extendable lightning connector, or USB-C if you have an android device.
My iPhone is in an OtterBox case and it does not take the lightning connector correctly. I have the lightning connector fully extended and it still doesn’t connect so I had to take my phone out of its case to use the FLIR One
1 - 7 of 7 Posts
