1 - 6 of 6 Posts
Ive been asked to correct a mess that an in house crew started.
They applied dry eraser paint to the drywall a few months ago and to this date, its some what tacky , and the board it useless. How Can i correct something like this without ripping out the drywall. Any special primer sealer that i can use?
30 year novice
Is it the black board paint that they used? What is the finish that is under it? The only thing I can think of why it's still tacky is that it's an 2 stage epoxy and they didn't mix it properly. Maybe try a test of Cover Stain and BIN and see how it dries and sticks.
If it is still tacky after a few months I can't imagine that putting anything over it is going to solve the problem. Will it scrape off? then maybe try using a reducer to wipe off what remains? If that would happen to work and the surface dried ok I would then prime the drywall with oil Kilz etc.
Nothing says any of that would work so as much as you don't want to I think I would lean towards replacing the drywall. It will be fixed right.
Good luck.
Good luck.
Exactly. XIM solvent based primer is probably you're best bet, and even that is questionable.
Maybe use Zinsser BIN to create a "hard shell coating" for whatever finish paint is used (if BIN even sticks). You'll probably be able to poke thru it with a pencil tho. Like I said... it'd be only a "shell coating". If the surfaces don't get banged around a lot, then...hazzah!
1 - 6 of 6 Posts
