1 - 12 of 12 Posts
I have a client that is looking to close off the damper and make the flue weather proof put wants to leave the firebox open to place flowers or candels in.
Is this possiple? If so what is the best method?
yeah wish I'd have though of the ballon Idea!
cool, this is what I'm looking for!!!
where can I find the caps you have pictured?,,,thanks for your input and time on this
Discussion Starter · #9 ·
never mind wasn't thinking , found a link and am going over it with the client, thanks again to all who posted!:thumbup:
Working
The masonry supply that sells fire bricks can get them as well as the custum sheet metal place that makes chimeny caps. Don't have to buy online, that's here atleast.
Cole
One thing to remember if you use a flue top damper(for a working fireplace)-- the damper it's self will restrict the flue size, and in some cases makes the flue section area too small for a good draw. The solution I came up with on my rumfords was to use the next size larger damper, and cut a piece of the next size larger flue to fit snug over the chimney flues at the top.--problem solved.
1 - 12 of 12 Posts
