1 - 7 of 7 Posts
90%-er
We're taking care of a list of inspector-requested improvements to a rental unit on Thursday. His list (although in the worst possible handwriting) makes sense, but one thing I'm unfamiliar with:
He has requested fire stop walls to be constructed at both bathroom vanity drain/supply line penetrations, inside the cabinet.
I get the reasoning, but have never faced this request before. I will certainly give the inspector a call tomorrow before our supply run, but I thought I'd do some research here first.
Is there a specific material usually called for in these circumstances? Or do we just need an extra layer of 3/4 ply or the like around the penetrations, plus fire blocking foam at the actual holes?
I appreciate the assistance and insight fellas (and ladies).
General Contractor
That wall is probably adjoining the apartment next door is what it needs to be fire rated. You can use fire-rated foam or you can use Mineral Wool Insulation, for 1-5 HR rating. Just keep in mind that whole wall assembly should be fire-rated.
Best would be to call him and ask the specifics, because every case id different and municipalities have different requirements based on the situation.
90%-er
Thanks folks. I'm going to give the inspector a call on the way in.
He is also calling for fire blocking foam at the penetrations, so I think he's looking for something else in addition.
Yes, it is a multi-dwelling condominium building.
This particular city has some strong local building ordinances, so I'm sure the separating wall is up to standards; inspector is just calling for something additional inside the vanities.
Great Stuff makes a fire-blocking foam, right? I'm sure I've seen it but not registered it because it's never come up.
1 - 7 of 7 Posts
