1 - 4 of 4 Posts
I have to put a clear coat of finish on some red oak and I would like to keep the wood as bright as possible. Can anyone recommend a product for this? I don't do a lot of finishing and this is only for the interior of some cabinets.
Thank you
Focusing on solutions.
Water bourne or pre cat lacquer will keep them as bright as possible. Both are water clear. But they don't do a lot to bring out the beauty of the wood. Leave it plastic looking IMO.
Radical Basement Dweller
I'd head to the hardware store and pick up some "wiping varnish" and wipe on 2-3 coats. You don't have to worry about taping off, overspray or brush marks. You should be able to get 3 coats on in a day if the humidity is decent.
You can make your own...50% polyurethane and 50% naphtha which will dry faster.
Probably the easiest finish to do with no fuss.
1 - 4 of 4 Posts
