1 - 20 of 38 Posts
Livin the dream...
Discussion Starter · #11 ·
Please say the tub deck is waterproof not just with durock. If not you are way ahead of yourself.
Schluter profiles will work nicely.
Kerdi Membrane
What sucks is the drop in is 60" and I've got a little less than 63-1/2" between the tile after its installed. Gonna suck to try and caulk around that flange.
Hair Splitter
Why would durock not suffice for a drop in tub?
Because all wet areas should be waterproofed. A tub deck gets sufficient amounts of water to justify waterproofing.
Hair Splitter
How much freaking water does a tub deck get, it's not a shower.
It's not a shower? Shut up! :laughing:
Do you not have kids? Ever taken a bath with the Mrs or Mr (I'm not judging)? :whistling
I've pulled out enough tub decks with rot and or soft wood. Heck, I AD the plywood and then the durock. AD is cheap insurance.
I also AD the floor, especially around the shower and tub.
Bathtub Jacuzzi Floor Tile
Room Furniture Table
Wood Room Roof Siding Floor
Room Property Floor Building Furniture
So many options.....as mentioned above.
With a tub surround, depending on the decor and trim package in the bathroom, I often like to install a painted wood trim border.
Many times, I find it ties the surround very nicely into the rest of the bathroom.
Backprime, backpaint, backbutter (adhesive caulk) and caulk well at wall transition (although the "border" is generally high enough to avoid major water, unless you have especially rambunctious toddlers (or wives)) .
Contractor of the Month
Good point, junio starts swinging his rubber ducky around you best have a waterproof floor to go with it.
1 - 20 of 38 Posts
