If it's tail base I end it on studs . Other wise it's miter and nail to base of walls with small molding .
Yup. I'm back in that house a couple times a month and still can't find the joints.:thumbsup:45 with glue and 23ga pins. Sand a bit if needed.
IIRC Lone had a thread where he made straight cuts then biscuited and glued the joints. I always wanted to try that but have not yet.
I used to butt my joints too, it does work well. A well scarfed and glued joint also works well, but your scarf has to be tight. Glue gets much more strength when you have tight joints vs loose ones. I scarf, sand, prime with spray kilz, sand and prime again. Sanding the primer gives it that seamless look.45 with glue and 23ga pins. Sand a bit if needed.
The nice thing with square butts is that you can spring the joint tight, which is the next best thing to clamping pressure. I've moved away from scarf joints for this reason. As for Kilz, we have a nickname for it onsite....Magic Miter Paint.lolI used to butt my joints too, it does work well. A well scarfed and glued joint also works well, but your scarf has to be tight. Glue gets much more strength when you have tight joints vs loose ones. I scarf, sand, prime with spray kilz, sand and prime again. Sanding the primer gives it that seamless look.
Yup. My thoughts exactly. I may go back to it someday but I like what I am doing now. Scarfing is faster, butting takes longer to pull off good results, but once you do, it's golden.The nice thing with square butts is that you can spring the joint tight, which is the next best thing to clamping pressure. I've moved away from scarf joints for this reason. As for Kilz, we have a nickname for it onsite....Magic Miter Paint.lol
After sanding pre-primed joints, we always hit it with MMP and touch sand.:thumbup:
It sounds like the method myself and a few others mentioned of butt jointing the pieces and using a biscuit and a backer would be much stronger. I could be wrong though, but do you and why do you think that method is better, stronger?Railman said:A few years back, I got involved in a thread with Gary Katz about a method he liked to do. I thought it was overkill at the time, but have since decided that it was a very good way to deal with extra long runs. If I remember right, he did scarfs on the flat at maybe 30deg, ca glued joint, & ca glued a backer strip across the back side. I could see this working very well on extra long hallways and such. The hardest part would be handiling a 32' piece in the saw. If it was 20 ft run, you'd glue up a 21ft piece, & do cuts. Joe
hmmm spot prime your scarf joints eh after sanding flush.. ill have to do this next time, i have a can of bin spray primer thats nearly empty.. ill give it a go..
might get some extra brownie points with the cute painter lady
Similar here. 22.5 scarfs, glued & nailed through the joint, bit of blocking behind it, over stud, pointed away from the door. The "why" is so I can nail through the joint.For crown and moulding I'll do a 45 scarf joint. I always have them pointing away from and as far away as possible from the door opening. My thought is if it ever opens up it would be less noticeable because your looking down the joint instead of into it. It doesn't help in all rooms or hallways but it's worth keeping the most common viewing angle in mind. Lately for square edge base I'll butt joint and use kreg pocket screws from the back. It would take a lot for a glued and pocket screwed joint to open up.
