1 - 9 of 9 Posts
I'm working on a project that requires fiberock aqua tough panels installed in washroom areas, ceilings are suspended 25 gage u-bar (high hat, 7/8" furring channel whatever) and walls are 3 5/8" 25 gage stud, I've had problems in the past with screws stripping in light gage stud, i was thinking of using 20 gage studs and channels to avoid any fastening problems, any other ideas? Maybe glue and screws on the walls and stay with light gage studs??
Ive used aquatough in the past and its a real nightmare. Folks its not drywall!!! Its Moisture Resistant Abuse board. The Architect that spec'ed it to be hung 25g studs should be shot. Try HardiBacker screws. The shank is much wider and use the pointed tip screws not the s12's (self drilling). THe wood backing is a way to address the issue and if its 25g metal its the only way
aquarock sux!!!! I just about forgot all about it till I read about it here. Thanks alot c.t. They should find the guy that thought that **** up and hang him. Or at least make him install some, so he knows how horrible it is to use. We did a whole pool room with it once, 25 foot vaults and all, I don't remember how many sheets of it we ordered, but it was a whole semi load. You will never get the screws to hold on the tapered edges with 25 gauge steel, doubt if even 20 gauge would be thick enough. The 2x2 stud screwed to the back of the steel stud is a good idea, it's the only way you will get it to hold. Now I'm going to have nightmares again!!!:laughing:
O ya, I would probably kill someone if I ever had to hang that crap again... Good thing I'm a pipeliner now.
1 - 9 of 9 Posts
