1 - 20 of 35 Posts
asked and answered (search button would also reveal results) ... three-four premixed bags per post per hole. 12"x30+" deep.
gravel in the bottom of hole under post for drainage.
just read an article today on a guy who uses one 60# bag per post per hole - wow.
not much of a footing...
Mac
I just installed 300' of privacy fence. I spaced the 4x4x8 treated pine postes 6' apart and used 1-80# bag of premix per post. I sunk the posts about 30" deep. I have seen fence companies use NO concrete. maybe thats why I see so many fences blown over after hurricanes.
Mac
I just instaled a flag pole where i used gravel under the concrete for drainage. in the back uf my mind though im wondering whats to feep the concrete from seeping down into the gravel and clogging it up, thus voiding the drainage ?
· Trailer park boy
Mac
3-4 bags:eek: Jebus.
I use 2, and sink the post 3 feet.
I don't like building fences... I don't do them often. Too much manual labor, not enough design work involved.
But when I do, they're solid as hell. Thinking of switching to 4x6 posts for future builds because the 4x4s still have some play.
I use 10' tall posts so I have enough sticking out of the ground for a 6' tall privacy fence.
Mac
Mac
When I redo my POS fence I'm thinking of going with a taller (longer) post so I can put vinyl lattace at the top without scabbing to an 8 footer.
Interesting thought on the 4"x6" too. I might have to give that some consideration too.:thumbsup:
· RDFLYC
do you concrete your posts in ?
it seem a lot of fence companies do not.
it all depends:
-wood: if You want Your wood post to rot out in time with the moisture trapped inside from the concrete which in the long run will cause the post to rot from the base. do not do this! dig a 30-40 inch deep hole with around the same diameter as the post and just set the post in with the dirt you dug out and tamp the post level!
but it still depends:
-metal/pvc: You want to always set with concrete! dig a whole about double the diameter of the post and around 30-40 inches deep and use type 1/2 cement with a good ratio of sand and stone mixed in to make a solid concrete; then just level properly and allow the post to set.
this is just the basics of post setting i suppose. let me know if you come across a hole you just cant dig or core drilling and quik-rocking! i can help!
I think it's a geographical thing. You can't set a solid post in sand but clay is a different story. I have seen a large amount of contractors where I am at stop using concrete to save money and get there bid lower. When you start cutting corners it could turn out pretty bad. A good fence starts from the ground up and that includes a solid post footing that will last as long or longer than the fence material. Regarding chain link, some contractors will only concrete terminal posts and drive the line posts. I set all my posts in a mix of concrete and a hydraulic concrete called quick rok. No c.
Fenceposts
I use a 4x4 9' , dig a hole thats 10'x about 36" deep, dry pack with a concrete mix then just add the water with a hose, leeching it in with some thing like a peice of rebar....
next year we will be switching to a 10' post and going almost 48" into the ground. i suppose it will be a real ***** if it breaks .....hahahaa.....
4x6 posts are a pain cause they are so much heavier.
we are up to about 200' every two days on fencing
happy erecting...hahahaa
price per post???
not sure where to put this on here so i am sticking it in here.
i was asked to put in some fence post and i am not sure how to price it.
i am putting in around 200 4x4x8 fence posts. i am drilling them in with a trac-skid loader with a 6" bit. thinking it should take 1.5 to 2 days with three ppl. no cement spaced about 6'apart i was thinking about $3.00 per post labor only. is that about right???
· Al Smith
About Tree Fiddy!!
http://www.google.com/#hl=en&source=hp&q=tree+fiddy+site%3Acontractortalk.com&aq=f&aqi=&oq=&fp=6b22d27f49a5e7dd
1 - 20 of 35 Posts
