Glue & screw wherever screws won't be visible... There are about 100 ways to do it if the screws can't be hidden. It depends on whether you're building the Yugo or the Cadillac...
You can pocket screw through the bottom side of the bottom panel to the side panels, back side of the back panel to the sides, and the tops of the box to the sides, and all will be concealed:thumbsup:. I have done this alot in the past.Well we're going for something a little nicer than a caddy, but our expectations are not much higher than that. We're going to add skins so the sides WILL get covered. I guess screwing would be ok, I've just never had a lot of luck with screws not splitting the plywood and causing ugly bumps inside the cab.
Pocket screws on the box? How's that work?
We tongue and groove all the panels, and we use 1/2" prefinished birch... so I don't see where pocket screws would work. We do use them for the face frames, though :thumbsup:
Well,.. sounds like you've already got it figured out then right?????we do a 1/4 x 1/4 dado in the face frames for the tongue in the side and top/bottom panels to slide into and glue it
