1 - 20 of 53 Posts
Have 5 false beams I am building out of 1x my problem is I have am running parallel to the rafters in a cathedral ceiling I have no meat to hit. Any ideas besides cutting open the ceiling and adding blocking. I thought of toggle bolts and cutting open the ceiling just where my beam is going and slipping wood blocking just behind the drywall. I really don't want to get into finishing a bunch of butt joints here
Are you building a three sided channel? I've done it where I made a three sided "beam" and then toggle bolted and glued a nailer board to the ceiling so the sides would slip over it and then get pinned to the nailer board.
Yes that's what I was planning on doing, but I never used toggles in a ceiling do they preform ok for this application in your opinion?
Head sawdust creator
Years ago, in my own house, I glued some 2x6 to the drywall on the ceiling of my living room to make false beams. I used BLACK STUFF drywall adhesive and just cut some 2x4 braces that were snug from ceiling to bottom of beam to hold them inplace until the glue dried ... no mechanical fasteners!! Been up there now for over 30 years!!
Reactions: Rio
Sweet thanks guys, I know this seems like an amateur question, but for some reason I keep second guessing myself on this one. I kept going back to cutting the ceiling open and adding blocking but that would be a finishing nightmare. I'm going with toggles and glue
For a quicker install besides toggle bolts or mollies, consider snap toggler's. They are great. Also you could use Toggler's and glue. Just pre-drill to locate the hole in the ceiling, install either, and screw the 2x with glue to the ceiling.
http://www.toggler.com/
That's all I use are the snap toggles I they are an all around easier product to work with.
Hypothetically, you don't install blocking but rather use toggle bolts in hollow ceiling. For some crazy reason, this beam becomes loose and falls and injures someone. Will you have a, "I wish I installed that differently" moment?
Or, would you be like, "there was nothing that I could've done to prevent that."
I always try to build for "worst case scenario". I don't know your particular situation, but in the future if someone was to decide to hang something from this beam, crazy as it may sound, it may fail if not secured to something solid. That failure could result in injury. Sometimes the best way is the easiest, but sometimes it's not.
Again, I don't know your particular situation, just -sort-of- playing the devils advocate.
Particulate Filter
Toggles and glue is a good solution that I would stand behind in court. I think most contractors expose themselves to significantly more risk driving to work than the one in 20 million chance that a homeowner is magically impaled by a false box beam.
Cathedral ceiling. A homeowner has no business attaching a trapeze or whatever to a beam in a cathedral ceiling. I'd take my day in court, too, and I wouldn't feel guilty about it, either. If someone's designer, or a contractor at some later date, decides to hang a 300lb chandelier, it's their business to make sure the support is sufficient.
1 - 20 of 53 Posts
