Hardie board isn't for exterior applications.
*Hardi says it can be used but only warranties warm climate applications. And Hardi 500 is different than regular panels. Personally, I dislike the dusty, dry surface of Hardi for tile applications. And wetting it before tiling? Did you wet it too much or not enough? Did you clean it enough or not enough? :sad:
TCNA doesn't have any specifications for the application as you're thinking of approaching it. The closest thing I see in in the guide would be to apply ply then a roofing membrane then mortar bed, with or without an additional membrane.
*The plywood would need to be pitched so water could move under the bed to the outside edge. A subsurface membrane between the roofing membrane and mortar bed is important IMO. Better drainage if water gets in somehow.
A sheet membrane on top of the cement bed is considered the secondary waterproofing but I feel is necessary. Sheet membranes are the best compared to liquids. Noble is my preference :thumbsup:
That seems like overkill for your situation but it may be allowing for the much higher changes in temp from a very sunny day, which could hit 150 degree surface temp, to -40 degrees.
* I think the cement bed heats/cools at a slower rate versus plywood so the membrane stays intact better.
I'd feel comfortable using a exterior glue plywood built up to the appropriate deflection and then NobleSeal with the seams sealed
I don't think the CBU really adds anything but height if you're using a membrane.
