1 - 20 of 28 Posts
I have read mixed reviews on what a good brand of exterior paint is? I am painting a house that is currently white and most likely will be painted white again, planning on power washing loose paint and debris. Then prime the bare spots and go over entire house with a coat of paint. Was thinking of using a primer/paint in one, what is a good brand to go with and should I paint 1 coat prime/paint in one or two coats regular paint and prime bare spots? The siding is wide wood clap boards. Thanks
· Store Owner
What type of wood?
Is the peeling between coats or down to bare wood?
Is the surface chalky?
1. Powerwash, use some sort of cleaner, be it a housewash or my TSP, bleach & water mix.
2. Scrape and sand peeling areas so theres no loose paint.
3. Depending on the paint you use, may or may not require a primer, but the product itself to be used as a primer.....before I make a reccomendation refer to my first 2 questions.
4. Paint ( whatever you choose ) I prefer Benjamin Moore, depending on the finish, either the Moorlife ( Flat ) or the Moorgard ( low lustre ) :party:
Discussion Starter · #10 ·
NC Paint 11
Its not cedar, I am guessing typical hardwood like oak..there is some peeling but not everywhere. Going with a seperate primer and a Bejamin Moore exterior paint. What is a good solution to go with just to get layer of dirt off and remove the loose paint?
NAV,
Yes I am a painter, only have done a few exterior jobs though and looking for some advice. You do not have to be a bastard, do not waste my time by replying. Thanks
If you are a painter then you should ask the paint rep that you buy all of your interior paint from on what exterior paint he would spec for the job. Whenever I stray from my normal routine I call my SW store manager and tell him what is up and what would he recommend and stand behind. We are here to help each other out but we do not help out hacks or homeowners.
· Store Owner
You guys ever seen IPE wood? Mostly used for decking...and man...its sweet. Expensive, but no more than that composite crap the box stores are peddeling. It will last longer too, and look nicer. Plus its fire resistant, the wood is so incredibly dense that it doesent like to burn. One of my fav's, off topic....but thought I'd share :)
1 - 20 of 28 Posts
