1 - 18 of 18 Posts
All depends. Sometimes solid wood, sometimes wood veneer, sometimes MDF. Lately we've been using the heck out of "veneered door jamb" stock for stained applications since it's 1/4 of the price and still "looks" like solid stock. Really helps in the budget crunching putting projects together with no money per say....it gets them "the look" without spending big time bucks.
· wannabe
For really wide extensions we'll use 1/2 AC... for regular extensions we use solid 1x. our local supplier carries select pine/poplar you could get either!?
stained,We match, ..........painted, as a standard is poplar.
If it's less than 2 1/2" or so, I try to use rips from the base mldg... that way it matches nicely.
You might have to tighten up the casing reveal a little (thinner stock)
Otherwise, wrapped jamb stock or the real deal.
I haven't been successful posting photos. I decided to do this first in a basement, where the walls were firred out. The jambs must be 10 1/2" wide. I thought there was no way to use anything but plywood on something that wide, and they always get so dirty and beat up.
I brought out the tile the thickness of the window casing. In this case, it was the real cheap ranch style oak window casing, 2 1/4" wide. It is about 3/16" thick at the thin side, so I had the tile come out proud of the sheetrock by 3/16" and it is flush with the trim installed.
Just be sure to use porcelain (through and through), so the edges look nice. You'll find on normal windows (less than 4" extensions) you can use up your scraps.
Of course you could also use granite, marble, whatever. You could also use one-piece sills as is common in other parts of the world.
· Banned
Poplar paints beautifully. That said, it's generally more expensive than clear pine, and it rots if exposed to moisture. I don't believe it stains well either.
I would use pine, unless I was doing stained work, than I'd match what was used on the actual window and/or trim.
· Scooter
Depends on what the customer wants. Pine, Poplar, Oak, Hickory, the flavors are endless.
One of the more popular flavors we have seen this year is using azek. Alot of customers that have had prevous experience with moisture damage along the sill want to use azek.
As long as the money is good, I would jamb it out in OSB:shutup: if that is what the customer wanted.:laughing:
I have a love:clap:/hate:furious: relationship with the white plastic myself.
1 - 18 of 18 Posts
