anyone know of any made of rubber? all i'm really seeing are nylon/hard plastic which don't look that durable.
As long as you don't have the cords out for others to use.The qwiklok ends are nice for the female end. They are plastic but seem to be holding up well.
I'm a one man show so I get to tell OSHA to ***** off if I ever see them.
https://www.amazon.com/dp/B00P04L40...=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9003017&hvtargid=pla-303143736885
Who says it has to be an electrician that does the work?I just buy good quality cords and when they fail I buy a new one. Unless you are having an electrician change the connector they are not OSHA compliant.
OSHA. Probably just an American thing.Who says it has to be an electrician that does the work?
Sorry, it's not an official stance. I was told by an OSHA certified sparky that you could replace but a certified electrician had to make the repairs. As I look into it, that doesn't seem to be the case. It looks like those repair ends are not OSHA compliant as the OSHA reg states the cord must be returned to it's approved state and since that approved state is factory one could not return it to it's factory approved state with those repair ends.Who says it has to be an electrician that does the work?
It's the same thing here but the "approved state" is up to the inspector.Sorry, it's not an official stance. I was told by an OSHA certified sparky that you could replace but a certified electrician had to make the repairs. As I look into it, that doesn't seem to be the case. It looks like those repair ends are not OSHA compliant as the OSHA reg states the cord must be returned to it's approved state and since that approved state is factory one could not return it to it's factory approved state with those repair ends.
CT should get a OSHA guy on here for a Q & A. That'd be helpful.
I get these Orange ends at Lowes.
They are better than any original or replacement end I've ever come across.
They stay plugged on tight and don't shatter in cold weather.
Sent from my SM-G950U using Tapatalk
