For an 8' ceiling, the only extension I'd use is my arm...pointing up.
Unless of course I was less than 5' tall, which I'm not.
Vandy -
I think I'll get the 12" for the 8' ceilings then.
I just looked up that swivel tip. A 45 or 180 ? What do you use it for ? Comfort or to keep the fall off your face ?
Also what tip to do door frames SW Super Paint SG latex.
For the grand finale question.......Can you describe how best to spray the walls when the ceilings are a different color ? Cut in the walls - then a shield a few inches from the ceiling ?
Its all previously painted dw and woodwork, house built 1965.
I won't be a rookie this time next week.
TUS :w00t::whistlingI think typical order is - and this was discussed at length in the 'spraying new construction' thread -
Spray ceiling
Shoot trim and doors (211-313 you should start with a 211)
Cut and roll walls
You could shoot walls, drop plastic (10.00 a room in tape and film), shoot ceiling, mask trim top and bottom ($$$) and still get over spray all over the walls, then come back and try and catch all the little mistakes and hazes from the spray. I'm pretty sure I can just paint and cut a wall in the time it would take me to mask off the trim. And the results are better.
