1 - 7 of 7 Posts
G
how's it going. i'm setting up a saltwater tank and i need some help with the electrical part of things. basically what i need is some advice on wiring everything into the stand, and as the saying goes <i>water and electricity don't mix...but water and electricity mix all too well</i>, want to do everything right. i need prolly 10-12 outlets, i want to have some kind of breakers and GFI's. i have very limited experience with electrical work so any help or suggestions is appreciated.
thanks in advance,
rob
General Contractor
Dang.. how large of a tank is it? I would suggest running a home run from your main breaker panel. 10-12 is about max for a typical home - and since you will probably have something running on all of them it will definately be maximum. You will probably need a 20amp GFI breaker and put into 3 - 4gang boxes into the wall. Now if you want them built into the case you could put the romex inside seal-tite piping from the wall into the case. You'll have to check the codes in your locality on remox outside of a wall cavity. I'm not sure if seal-tite can be used in that situation. Might have to go with Flexible MC.
thanks for the reply, the tank is a 75gal with a 29gal sump. i didn't really understand much else from your reply:D so let me rephrase my question...or put it this way, the link below is to a thread on another board. the first page has pictures of the in-stand wiring i'd love to have in my stand. the thread has a lot of images...just a warning.
http://reefcentral.com/forums/showthread.php?s=&threadid=273216&highlight=drilled+tank
In my tank(terrarium) I use 3 plugs, light, fogger, water filter. The fogger and the light are on timers. At no point does anythng electrical touch water except the fogger which has been engineered to be submerged under water.
I use a typical surge supressor/power strip on a 110 volt line.
General Contractor
Those pictures show just about exactly what I was trying to describe. Seal-tite is a flexible plastic like tube with waterproof connections. MC Cable is Metal Clad Cable - also flexible. I was saying to use that to run the wire inside the case.
I think, as the pictues showed, you could do it easier with the power strips they are using. I don't quite understand why they have the power strips and the outlets. Seems like it would be half the labor if you just used the power strips.
Electrical Contractor
While that looks like a nice neat job the whole thing is highly illegal. All that 120 volt wiring in no conduit or sleeve with the plugs on the ends is a huge no-no.
The power center looks factory installed and is the way to go. I would use that type of setup and just use another power strip mounted inside the cabinet. Use a good quality strip, not the $6 Home D. type strip.
I would consider running (or have an electrician run) a multi-wire circuit to the tank area. This is a cable with three conductors which can serve two circuits. I would install a GFI receptacle on one circuit and a standard receptacle on the other. Any critical loads such as heaters or filters can be taken from the non-GFI circuit and any incidentals can use the GFI for a little extra safety.
GFI's can nuisance trip at any time and if you are not around for a while you may lose some expensive fish or plant life.
G
Discussion Starter #7
save time and money call a lisenced electrician he should know the codes and get it don in half the time you could.................
1 - 7 of 7 Posts
