Evaluating Fibafuse Tape
25K views 19 replies 11 participants last post by  artinall
Fibafuse seems to offer low build qualities (less tapering) & strength...
Does it offer any real worthwhile antimicrobial properties? One customer told me his prior drywallers wanted to apply it but he refused, thinking mold in the lower basement may catch hold in the tape.
What I really want, now that I've taped with it on several patches, and before I have it over a multitude of projects (only recently) -- is how strong it holds relative to paper tape. Is it really stronger even on larger patches secured 16" on center even? Over time?
#2 ·
No, but think about it. It's made of glass. Not a microbe killer, but certainly not something yummy for them. It's essentially neutral.
As for strength, good question. In the raw, it tears more easily than paper when stressed at 90°. But I would venture to say that when embedded, it would be stronger longitudinally than paper.
#8 · (Edited)
I use Fibafuse, and I can't say that it is any better or worse than ordinary mesh when it comes to repair work. I have seen it crack at factory edges and butt joints just as often I have with paper or regular mesh. Most often, it had been applied improperly, as I have been running into a lot of repairs the past 4-5 years with Fibafuse bedded in with regular mud and seeing the fiber ends sticking out the through the finish in slick walls and ceilings.
My only serious knock against Fibafuse is when I am doing patch work repairs over thick nugget knockdown finished walls. Regular mesh seems to be a little more pliable and takes less hot mud to feather the repair into the surrounding area. The ends of the Fibafuse strands are a little more rigid and will tend to pop through the hot mud unless I coat it more heavily and bust the repair out wider before tooling it down with a 6" knife as it sets off.
With that said, Fibafuse does make a thinner mesh, and I have 4 rolls of it on the shelf out in the garage. I will try the thinner stuff eventually and how see how it works.
As far as it's ability to withstand mold? It is a nice marketing ploy, but why would I care about this at all? If you have mold at the board joints, then you have a much more serious problem than worrying about the type of tape you have been using.
#12 ·
I stick with mesh. Fibafuse is a pain for me. It tears and leave strands and also seems to want to raise up more. Not to mention trying to find the end on the roll.
And for you new guys......I'm 100% patch and repair. No time for paper. New construction, whole houses always get paper here.
And they never sent me my free roll. How long ago was that????
#13 ·
Fibrafuse is the way of the future, I use it all the time, Cleaner, less chance of air bubbles, but there is one drawback... in the angles. I likes to tear when flushing it, or at least i find it to do that.
Runs through the autotaper easily, coats over nicley, dries quicker than paper tape.
All in all a great product. It costs more, but it evens out if you cut any call backs out of the equation.
#14 · (Edited)
Fibrafuse is the way of the future, I use it all the time, Cleaner, less chance of air bubbles, but there is one drawback... in the angles. I likes to tear when flushing it, or at least i find it to do that...
I get that too. Which begs the question - can paper tape be applied overtop the fibafuse, are the two "compatible".
Like for a ceiling or wall patch that includes the corner?
#15 ·
Fibafuse "integrates" with compound better than paper tape; I'd be confident paper over fibafuse would work even better than the converse.
Which still begs the question: Why would you use fibafuse in a corner to begin with, since you know it's susceptible to that tearing? Leaving aside the fact that a guy with a good touch can do that.
#17 · (Edited)
Which begs the question yet further, even for a guy with such a touch as my own would consider, given the advantage of fibafuse on the remaining sides versus what lingering uncertainty of compatibility remains...
I'll use fibafuse over paper all day long except in corners unless you're Hispanic and use your hands to apply mud. I have repaired mesh countless times and refuse to use it, it's junk.
And what do you mean "compatible'???? I use paper or something like Strait flex in corners, fibafuse on flats does that mean something's going happen where they overlap? It's not like they adhere to each other without mud.
I'm repairing mesh on the job I'm on right now.
Any time dissimilar materials are being used in contact with one another I tend to question ...
#16 ·
