Hi guys....and girls...
Designed a tiny home with a slightly different roof line and have a couple of questions on the install. I'm using 60 mil Carlisle EPDM.....unfortunately I couldn't get anything wider then 10ft, so they'll be 4 seams and the first one will be centered at the middle of the 14'x40' home and working out each way from there. Roof has 7/16 OSB (rough side up) with rafters at 16" centers. I'll go over the roof deck with some 100 grit and soften any burs etc. before I lay the EPDM. Was thinking of wrapping the EPDM over the edges about 3" and fasten with roofing nails, possibly put a bead of lap sealant and or between the EPDM and wood 2x10 facia..(?), where the nails will penetrate. Place brown aluminum drip edge (2 1/2" (top) x 1 3/4" (hangs down facia)) on roof and securing with ring shanked nails/roofing nails(?) and finish with the Carlisle 6" overlayment strip. Cut EPDM flush with the bottom of the drip edge. 10" metal facia will be stuffed up between the membrane and drip edge.....caulked where the drip edge meets the facia if need be. Alls seams with have the 6" Carlisle Securtape. Most likely use 2 coats of bonding adhesive for maximum adhesion on the OSB. Does this sound OK relative to the design of the roof? Do i need termination bars? Assuming I need 1/8" gaps between the 4x8 sheets of OSB. Also....I'm putting a low slope wood stove flashing on the roof (stove pipe will have a spark arrester) and not quite sure how to seal it....being galvanized steel and all. And......Being that the trailing edge changes to a leading edge on the same side of the roof...should I be using any lap sealant on the edge/corner of the roof.......where the EPdM stops?
Ends of roof are a 2/12 pitch (opposite to each other) and rises and falls 3/4" per foot, flat in the very center.
Thanks.
Where oh where do i begin?
Do u really think youre going to get 3" iso board to lay down on that deck and look good? And technically youd have to go with 3.5 or 4" now due to the change in code.
With an epdm roof id go with 5 inches cuz its going to be a frecking sauna in there.
U can get tapered iso board you know.
Btw Sanding the deck? Totally unnecessary. If a splinter could pierce the material, id be really uncomfortable with using it as a roof on my house. Have you ever seen/felt .060 mil?
The overhang and drip edge on top with roofing nails to secure?
Gawd please.. 1st metal isnt super forgiving. Especially L shaped metal. So whatever edge metal you do use, you probably need to get custom fit. And it will never go over the 3 inch overhang. That is typically an application done on a parapet wall when a cap goes over the top and can pin down the material on both sides. Then another cap goes on top of that or the seams are covered by another layer of metal.
Nails on fascia side? Negative
Cut edge sealant is not used as water cut off. Totally different product totally different uses.
Water cut off is used with termination bar when the membrane is stopped on the inside of a parapet wall going up the wall. Between the material and substrate with termination bar pressing that bead of sealant against the material and wall. Hence the name, water cut off. It needs to have direct and constant pressure in order to be effective. Its not caulk. It is hella messy and will get all over everything and everyone and youll never get it off of you or the roof. use with caution.
There is tpo coated metal, which you would use to attach tpo membrane (what you should be using) to the drip edge. You weld it like its a seam. The coated metal is flexible and you can fabricate whatever flashing you need on the roof with it. Use cut edge sealant on the edges of the material that you cut.
Use seam tape or cover strip if you want but really if you install it correctly thats unnecessary.
Id skip both of those tapes and use eternobond if i were to use anything at all. Make sure u prime first.
Youre going to need to start from the ends and the last piece you lay goes in the middle you know? That way the water rolls over the laps instead of into the lap.
Gluing it down? Mehh. Glue is a pita if you ask me but i suppose its a necessary evil on this roof.
Cool design btw. Im curious how its going to shed water and how youd gutter it.
