1 - 2 of 2 Posts
I have a small retail buildout coming up that specs eliminator track. Grid to be installed at 10' then frame walls. The obstacle I see is the 2' radius wall corners. I have not seen radius corners with eliminator before. Is there a compatible bending track or should I just frame with regular track. Thanks in advance for your feedback.
eliminator track is great I guess, i would rather install zip bead myself, but I would frame with regular track and zip later. they will never know the difference. I use non combustible plywood all the time for backing and the prints spec metal backing. the metal puts a large bump in the wall and the ply finishes smooth
1 - 2 of 2 Posts
