bummer, was hoping I'd get some input on this one.
anyone know any good contractors in CA to sub to, or a good place to find one?
Thanks.
Thanks.
That explain why I don't get to work up there. We do lots of work across U.S. and Caribbean Island but not up north. I wondered why multi-lamps ballast can't be use there? Is it harmonic resonance? Are you on 50hz. grid?In Canada for lighting retrofits, if you have an 8ft lamp you have to install 2-4ft lamps with a single ballast each. We dont have any multi lamp ballasts, and they cant be used. One lamp per ballast, every third one has to be battery backup. Even replacing hibay MH, you can use T5 lamp "troffers" but one lamp per ballast, one battery backup per. Wages start for non union journeyman at just under $75 per hour, an extra $15 for working overhead, so retrofit would be overhead unless you can get them to lay down and do it on their side, that does work. US workers can't work up here due to HIGeh and the GAFClue Statute.:whistling I hope this didnt ruin your proposal and you still are able to make money on these jobs`
On another note I am going to bid on a job in Ukraine, anyone know......
You HAVE to be freaking kidding me!!!In Canada for lighting retrofits, if you have an 8ft lamp you have to install 2-4ft lamps with a single ballast each. We dont have any multi lamp ballasts, and they cant be used. One lamp per ballast, every third one has to be battery backup. Even replacing hibay MH, you can use T5 lamp "troffers" but one lamp per ballast, one battery backup per.
An EXTRA $15/hr for working overhead???? Once again, you HAVE to be kidding me!!Wages start for non union journeyman at just under $75 per hour, an extra $15 for working overhead,
What the... this is not true... :blink:In Canada for lighting retrofits, if you have an 8ft lamp you have to install 2-4ft lamps with a single ballast each. We dont have any multi lamp ballasts, and they cant be used. One lamp per ballast, every third one has to be battery backup. Even replacing hibay MH, you can use T5 lamp "troffers" but one lamp per ballast, one battery backup per. Wages start for non union journeyman at just under $75 per hour, an extra $15 for working overhead, so retrofit would be overhead unless you can get them to lay down and do it on their side, that does work. US workers can't work up here due to HIGeh and the GAFClue Statute.:whistling I hope this didnt ruin your proposal and you still are able to make money on these jobs`
