1 - 10 of 10 Posts
I have a shower that I did 7 years ago that appears to have some sort of white crystals in the drain near the weep holes. My plumber said it was efflorescence. I thought efflorescence was powdery, this is not. It looked to be like hard water scale but a lot of it.
It does not show on the tiles near the drain at all.
It takes 4 months for it to almost close the drain 50%
Shower has pre slope and PVC pan
Very hard water in the house
Any ideas on what it is and how to eliminate it before I take out the drain to check further?
I've seen that too. I don't have any answers other than chip the crystals out.
Could it be the type of soap/shampoo that helps cause this?
That's what I was thinking in addition to the hard water. I may see if I can get the crystals tested to see what the actually are.
Very weird because there is nothing else showing at the top of the drain.
· Tile & Marble Contractor
If the weep holes were clogged would the problem show up in the tile especially by the drain?
the grout around the drain would stay wet.
you probably just have some minerals drying in the grout around the drain.
could be the water in that area.
1 - 10 of 10 Posts
