1 - 7 of 7 Posts
Eric R said:
Where did you get the bit? Did you have to make one?
I took a ground rod driver and used that for the shaft. Then took a steel pipe that fit the round stake , I think I used 3/4" black pipe or 1" then welded a nut on one end. Took a grade 8 bolt and threaded and welded it to the nut. Cut off the Hex End and fit it to the rod driver. Instead of welding it I drilled a hole though both and inserted a nail. Allows to change for steel stakes or ground rod.
You maybe able to weld it instead of a pin , but so far its working good.
Get hole saw large enough to cover the stake, , put a 1/2" bolt , washers & double nut bolt so shaft of bolt sticks out, use ground rod driver to drive bolt , Hole saw keeps driver centered on the stake. I used this for driving posts on a chain link dog run. ay have to tighten the nuts every so often.
1 - 7 of 7 Posts
