[Who does your flatwork again?]
I do.
Then you suck. :laughing:
If your work is flat enough to set on, but you still gotta glue down cbu to get it up to where it should have been in the first place, well then, really.....
OK, pulling back a bit. You do great flatwork, which you set tile on, or 10 years later or more come back and set tile on, great. You're a good man. But if you think you can just slap down a piece of cbu on someone elses pour and have it work out, well, I think the voids ozlo alluded to would come into play, so the person would have to play with mud to get his flat surface, well, flat. So why not ditch the cbu in the first place?
I dunno as most of the residential remod stuff seems strange at times to me. I think there will not only be cold joints between the sheets of cbu (seams) , but also between the cbu and the slab. Remember, there's no mechanical fasteners, so it's all cold joint chemical.
Alrightly then, so apparently the only remedy would be to put down some ditra, then cbu on top of that, then tile. :laughing:
Durock...doesn't compress under load. In this sense, it's as good as a slab in terms of supporting tile vertically.
You've touched on something I've always wondered about--why glue and screw durock to the floor if it moves? Wouldn't this make it a floating 'bed'?
Over a slab, durock can perform as a crack suppression membrane
Horizontal cold joint?
IMHO, guarantees given by manufacturers are little more than a selling point at the point of sale. Manufacturers will only help you out if you do any volume.
