1 - 9 of 9 Posts
Just finish spraying a exterior of a house with Duration flat, and the whole house flashed out on me. Never had that happen before. I have sprayed 5 or 6 house this year using Duration satin and never had a problem. This should have been the easiest job I had all year just a re paint, siding really didn't even need painting. It look worse now then before I started. I was wondering if anyone else has had this problem this year or just an isolated issue?:mad:
Nope. Get a paint rep out to look at the job. You may get reimbursed for the cost of the paint if its a bad batch.
I called my rep, he gave me free paint to do it again, and I had the same problem. I am up to 20 gallons of free paint to cover some of my labor. We quit today until they figure out what's wrong with that paint.
It went to there lab to get tested.
The times I saw blotchyness was when I applied gloss oil over wide wood trim too late in the day and it looked like crap the next morning. The sheen was all over the place, shiny here dull there. I think we're describing the same appearance even tho I was using alkyd semi-gloss and you were using latex. Flashing = blotchyness.
If the same thing happened after getting new paint, then that is kinda weird.
As the paint store manager, I would have looked to see if your second failure was from the same paint batch. You might want to ask that of somebody.
1 - 9 of 9 Posts
