Yeah way too many things could have caused this. Another is what adhesive did you use to secure the boards. Some can shrink and some expand. If you used a solvent based adhesive it could have shrunk.
Ask any commercial D/C that deals with metal studs about screw pops ... THEY HAVE NONE! The mills are allowed to send timbers out with a percentage of moisture . 8-10 % {I THINK}
Wood dries out from the outside in .... The deeper the screw is set the worse the screw pop will protrude .
Like said ,,, There are other variables . PROPANE HEAT!!!! A BIG NO NO !!! during finishing and paint ! Propane and space heaters [kero] are humidifiers ! [wet heat] Drywall finishing needs a dry heat!!!!
another note added to this is, if there natural gas connected to the house, get a natural gas heater its Dry heat vs wet heat from the propane heater.
When the trusses show up and they slap em on the ground without any cover....Then they get snowed on /rained on etc.. Not only was that lumber green from the mill now It's soaked with moisture ! DOUBLE WHAMMY!!!
It ain't rocket surgery ! DRYWALL ! key word - DRY!
If the frame hasn't cured then It's not ready for drywall!
I did a small warranty repair yesterday in a new developement. I was looking out the window and saw all the pretty new trusses for the house across the street exposed to the rain and sunk into a foot of mud.
.Thats what happens when they try to gear the rock to do it yourselfers..
Hi all,
The primary causes for fastener related issues are over driving fasteners into the panel breaking the paper, and lumber shrinkage, or a combination of both. Lumber shrinkage is often the result of high moisture content in the lumber which is not allowed to properly acclimate prior to installing and finishing the wallboard. Refer to the USG Gypsum Construction Handbook for help in repairing and mitigating these types of issues.
Also, please message us directly with your contact information and we are more than happy to look into this issue further and help remedy.
