drywall over drywall
3676 Views 11 Replies 7 Participants Last post by  icerock drywall
I am looking at doing a job that will require installing drywall over the existing drywall to cover some gaps after straightening the basement walls. I have never installed drywall over drywall what tips or suggestions can you throw my way? Would I still want to use an adhesive? If so what kind/brand?
1 - 12 of 12 Posts
First off, don't use 1/4''. 1/2'' is better. Find all your studs and mark them. Liquid Nails works fine.
You should only need to glue mostly corners where studs are buried.
Good luck
That was my plan 1/2 and LN adhesive. Wasn't sure if there was anything else.
I use 1/2 sheetrock, gyp screws and pl glue.
I agree with big shoe ...Use glue where the studs are hidden .
There's really no need for glue in the field unless you know for sure that the existing drywall was well glued and still has a solid hold/bond.
Tight bond glue Is My glue of choice..OSI just ain't the same glue since they went 'green' [poor bond] imo.. Tight bond Is A good product.:thumbsup:
What kind of gaps are you covering?
The gaps are where the ceiling and wall seam pulled apart and at most are 3/4" of gap. The other reason for laying over the existing is that the anchor bolts holding the plate against the block wall is flush with interior side of the SR. I don't think the current SR is glued at all so would it due any justice to glue this lay over?
I would not glue the second layer, but I don't glue walls. I only glue ceilings, and only on wood framing. Did you ever think to just prefill gaps wit 20 and skim the walls? What kind of anchor bolts?
This will require a second layer of rock as the anchor bolts are flush with the interior of the Sheetrock. The cutout for the anchor plate is about 18" x 32" and the bolt head is about 2" in diameter. There are about 8-10 on two walls in 4 different rooms.
don't put a butt on a butt
Same advice for spooning.
Reactions: slowsol
1 - 12 of 12 Posts
