1 - 20 of 20 Posts
ok this one is a bugger because theres nothing on it in my drywall book and its impossible to find anything online about this unless theres a term i just dont know so im caving in and here i am asking lol.
i have to finish some bare drywall on a ceiling. the side walls are finished and i cannot tape the edges and corners because of this. the home owner suggested cutting back the finish, but thats alot of work and its going to be noticeable like crazy. UGLY basically.
so i was thinking high porformance spackle. that stuff holds really strong. any other suggestions?
thanks guys!
^^ These guys got it right, crown covers all and if you can’t do that, then you should do it right and just repaint.
That being said:
A old plasterer showed me a trick that works for plaster but I’ve never had to use it for drywall but I think it should work. You could mesh the corner but only put about 1/16 – 1/8 of the mesh on the vertical wall. Go over the mesh with hot mud and stay off the wall. The mud thickness should cover the mesh completely and if you put it on straight you’ll have the mesh in the corner and a clean wall. Win win! (still best to do it right though)
thanks guys!
ya mean theres a book???? dern wish I had known that !!!!!!
really man,,, just tape off the wall with blue tape, then flat tape the ceilings, sand, then cut the tape line with a razor knife and pull off.
Thats GOT to be in the book,,,,,, just look a little harder
Discussion Starter · #10 ·
Sand and prime the top corners of the walls. Mud and tape. Prime and paint.
thx for all the good ideas guys! this seems to be a good topic. :clap:
one issue thourgh with sanding and taping, or using the blue tape meathod of taping then cutting, im going to get a challenge.
how do i get the texture to look right down the wall on that 3 inch strip that i sand or cut away? i have a redtail texture gun..... but is there a hand method? cuz matching texture seems to be a big nono in most cases.
maybe ill just do crown.... seems to be the smartest way to go here guys.
Smart phone? Scan me!
oh man. so the walls are textured? Is the ceiling popcorned? What is going on with everything (more detail) AND what the hell happened to where they would "finish" without finishing? :no: takes all kinds.
Discussion Starter · #14 ·
ya lol the walls are textured the ceilings had damage i guess. it used to be a crackhouse so u never knew wth happened.
so im really thinking to just slap some trim up on the walls. i want to avoid using crown though (expensive. this is just a rental for my customer. she wants things done cheap)
do u think i could get away with just plain door casing around the top?
Discussion Starter · #15 ·
Oh this changes everything since the walls are textured.
Give them a bid for sheetrocking an entire house, after you give them a ballpark on demolishing the existing and rebuilding - that's the only way you can overcome this obstacle.
they want to keep the walls that are there. its not my house and honestly it would be a dumb business move to do what you are suggesting because they will simply say nogo and hire someone else. we are talking about turning a 400 dollar job into thousands which i know they will not go for. they are aware the texture wont match but they dont care.
Well then just hang and finish ceiling then take your hopper and hit the ceiling with a texture as for the corners that meet the ceiling fill them with Durabond 90 in the brown bags texture by hand to match at the top of your walls done deal. then paint it out.:thumbsup:
as for moulding :no: and door case moulding:whistling:no:
Profit is not dirty.
If all she wants is to rent the place out, then re-do the ceiling as required, then around the edges take 1/4 round mounlding, and then dap the top and bottom. Done. easier than crown and is inexpensive.
Hope that helps
J
1 - 20 of 20 Posts
