I'll try to answer your questions best I can - as well, use the search function and you should find tons of info in DIB.
1) cons - dry ice as a media is expensive BUT you should be able to get a decent rate from a local gases supply company (ie Praxair, Contenential Carbonic, Air Liquide etc.)
- short shelf life - sucks when you buy the dry ice and job gets postponed or canceled etc.
2) Food service industry is a huge market - most are using dry ice or have their own machines but I still find they like to sub the work out. Basically any manufacturing plant that cleans but doesn't want the mess of water or soda etc. My MAIN industry is Mould - most of my mould work consists of dry ice blasting (attics, basements, crawl spaces, Marijuana grow ops)
3) going rate varies depending on what you are doing, like most blasting work...I basically just do mould at the moment an I charge a square foot fee BUT because of the type of work (hazordous...not really but it is considered this) and other things involved before you even blast its a totally different charge.
Well, if he's only using chemicals he is certainly not a 'mould guy' and doing things incorrectly BUT if he follows all other guidelines and sprays (if thats what he does) and sands and physically removes the mould from the premises then he's ok...sorry, I come across that ALL too oftem when a "Mold Remediation Contractor" has been in before me and sprayed a chemical and charged an eroneous amount - LEAVING the mould there...it doesn't just vanish after spraying...lol.
I have a chance to work with a guy that has a dry ice blast set up mobile with a 375 compressor airless and hydrostatic paint set ups and a shop for inhouse work, basicly he's looking for someone to do the work and he supplies all materials, equipment etc. he doesn't want an employee or to pay me an hourly wage he wants someone to run the show find the work and do it and take a percentage , I have a couple of questions since I know nothing about dry ice blasting, 1/ what are the pros and cons of dry ice and 2/ what are the main markets for dry ice comparied to regular blasting and how market and get the jobs 3/ what is the going rate for dry ice blasting. this sounds like a great opportunity but not if I can't find the work, it's very hard to get into the fire restoration side around here because they seem to use there own equipment or out of town companies, I have a "IN" at a mold removal company but he says he uses chemicals for 90% of his work
