looks to me like you have a leak from the hose to gun connection. remove the hose and see what's wrong. could be a damaged oring, bad sealing surface, or if its NPT it may just be loose. I am curious is that 4500psi hose? That looks like the same hose we use for 4500psi air. I'd bet a nickel that when you remove that hose there is a 011 oring. Replace that and you should be golden.
I've had this problem before.. I doubt its the guns fault. The grease your using seems to be a bearing grease. try a thicker lithium grease. I never had a dripping problem with a thick white lithium.
All of my grease guns will do the same leaking. It is worse when the heat is higher but I've not had one that won't leave a puddle here or there occasionally.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
