Topic is under debate :w00t:is drip edge necessary on the rakes? we are using it along the eaves.
I feel drip is necessary weather code requires it or not, however, to answer your question I'd put it on for at least good looks if you're already putting it on the eaves. That would just look too look tacky.is drip edge necessary on the rakes? we are using it along the eaves.
it is if you don't want drooping and cracking edges, or want to stop wind driven rain from getting to the roof deckDrip edge isn't necessary anywhere, as long as the roofing material is applied properly. But you're going to have a tough time of making a good-looking job without it.
Technically true. OTOH, any day of the week I could show you multiple decades-old sheds with no drip edge and healthy roof decks. :thumbsup:it is if you don't want drooping and cracking edges, or want to stop wind driven rain from getting to the roof deck
We always run a rake edge here and all the jobs that have specs require it.
The specs always required rake over the top of felt paper to keep wind driven rain over the top of felt.
Also:
It will help hold aluminum facia if the HO ever decides to go that route.
IMHO,I always use I&W at the rake, and the drip edge is always installed before the I&W is put down. So the I&W is ran OVER the drip edge on the rakes, and under the drip edge on the gable ends.
If water penetrates the roof at any point and runs down the underlayment at the rake, it will run right behind the drip edge/fascia.
I've seen some, some from ice too. I also like putting the drip over the underlayment on the rakes.IMHO,
It's a nice precaution,but I believe it is overkill and just another way for more I&W to be sold.
Thirty something years of tearing off roofs and never saw any damage from leakage along the rakes.
Agreed.IMHO,
Aluminum, no contest. Galvanized will rust sooner or later. Every nail hole and cut edge is a starting point.Maybe a good question toinclude in the discussion is do you prefer aluminum or galvi drip edge and why?????
Also works better with the rest of the flashings for a roof. Metals should not be mixed.:no:Aluminum, no contest. Galvanized will rust sooner or later. Every nail hole and cut edge is a starting point.
