21 - 29 of 29 Posts
The Grand Wazoo
I wasn't sure where to put this. Ok I am adding two small led work lights in the bumper on my utility body. The bumper is 1/8" powder coated steel.
Long story short, I added some to the body, but the bumper has clipped corners. So these lights will shine out to the sides a lil for backing trailers at night. I don't want to put them under the bumper because its pretty low.
I have to drill two 2 1/8" holes. Do you guys think a high quality hole saw and cutting oil will handle this? I would even buy one hole saw for each hole.
I would hate to start drilling and have the hole saws not work:laughing:
Thanks, Dave
My Milwaukee magnetic drill would do that chore no problem.
Head Grunt
Back in my off roading days i built new bumper brackets that were frame mounted and went through the bumper and had 1.5" eyelets for shackles/tow straps. The brackets were 4" wide and 3/4" thick. I drilled them with hole saws on a drill press. Ear muffs, eye glasses, can of oil and a large quantity of beer is what it took to get it done. Very time consuming but perfect holes when done. I only use Lenox or Blue Mole holes saws, very best IMO.
Administrator
Maker of Fine Sawdust
I've had my bigger forstner bits sharpened and they give them a sawtooth pattern. I can't image they wouldn't do a holesaw. The smaller ones might be difficult for them, but 2" should be a pc of cake. You might have to leave the mandrel with them if it's the first ones they done, otherwise I'm sure they have the setup to do it already.
Had you been using one of those Hougen cutters it would have only taken a sip of beer :laughing:
21 - 29 of 29 Posts
