1 - 20 of 29 Posts
I wasn't sure where to put this. Ok I am adding two small led work lights in the bumper on my utility body. The bumper is 1/8" powder coated steel.
Long story short, I added some to the body, but the bumper has clipped corners. So these lights will shine out to the sides a lil for backing trailers at night. I don't want to put them under the bumper because its pretty low.
I have to drill two 2 1/8" holes. Do you guys think a high quality hole saw and cutting oil will handle this? I would even buy one hole saw for each hole.
I would hate to start drilling and have the hole saws not work:laughing:
Thanks, Dave
Fine Handcrafted Opinions
I watched my plumber drill a 4 1/2" hole in a 3/16" steel panel on a grease trap the other day. Took him 2 $40 Lenox hole saws, but he went slow and kept spraying water on it, and he got it done.
Dave, I have, and, only buy the Lenox bits! worth the price ya pay!
If it is not hard steel, one bit should be fine! Go low pressure and slow. Get 2, save the trip to HD for the other! lol IF ya need a gorilla to help out, My son is available!! LOL ya know who he is!!!! Chad. ask dad!
Thanks for the input guys, that's good news!
Yeah, a good hole saw will do it. But pack a lunch if you're not using a drill press. :laughing:
I learned that a year ago drilling 3/4" holes in a 3/8" steel flitch plate:laughing:
Needless to say after about one hole I went and rented one of those electromagnetic drill presses:laughing:
Hey Dave,
Yup the lenox is usually all I get. Yup you know it! I was deffinetly gonna get two, I always can use the 2 1/8 for door locks.
I will stop in the fire hall and put him to work lol!!
I seen one of you guys vans the other day, I think it was on babcock blvd. I was going to try and get next to it, but there was too much traffic lol.
Carbon Dioxide Producer
I find that a hole cutter usually works much better than a hole saw for 1/8 steel, especially if you're using it with a portable drill. They cut cleaner and faster with less heat and run out than hole saws so your lights will fit in the holes better. Hougan is the brand I use, so they are what I would recommend.
Hole Cutter:
http://www.amazon.com/Hougen-14266-...?s=industrial&ie=UTF8&qid=1392040963&sr=1-113
Arbor:
http://www.amazon.com/Hougen-14009-...6?s=industrial&ie=UTF8&qid=1392041137&sr=1-36
Hole Cutter:
Arbor:
Wouldn't he better off with the carbide version for 1/8" steel?
http://www.ohiopowertool.com/p-459-...es-sheet-metal-cutters-select-size-pilot.aspx
http://www.ohiopowertool.com/p-889-...0-series-sheet-metal-cutters-select-size.aspx
The 2 1/8" HS version is $27 at above site, & the carbide is $54.
I've cut more than a few with a std carbide hole saw. You just need to use max 500 rpm, spray with WD40 now & then, & do a sloooow wobble so as to get enough pressure on the teeth to cut, instead of just dragging off fines. It's kinda similar to rocking a hand saw when you cut wood. The tooth pressure has to be right to dig in.
Joe
Artisan Carpentry
https://www.ohiopowertool.com/ShoppingCart.aspx?add=true&ReturnUrl=kitproduct.aspx%3fSEName%3dhougen-holcutter-14200-series-sheet-metal-cutters-select-size-pilot%26ProductID%3d459%26cartrecid%3d0
Joe
Joe that link is just to your shopping cart.:laughing:
Administrator
Sawdust follows Me Everywhere
$28 for 2 lenox hole saws or $70 for the kit for the Hougen kit. Especially if you have the mandrel for the holesaw already. You can get the holesaw sharpened again for about $4-6 at your local sharpening place.
Your more than welcome to use my cart! :laughing:Just YOUR card to check out, & have shipped to my shop. I'll hold your stuff for ya!:jester:
I figure if you have my credit card info, it woulda been used by now anyway.:whistling
I'm actually going to go right by that store tomorrow on a delivery & measure run in Columbus. I might have to stop in & look around.
Joe
Discussion Starter · #20 ·
Thanks leo, I didn't realize hole saws could be resharpened. I'm heading to pick up one of my saw blades from my sharpening guy this week, I'm gonna ask him about the holes saws while im there.
Railman, Just post you credit card info here so we can make sure we didn't use yours:laughing:
1 - 20 of 29 Posts
