1 - 18 of 18 Posts
Got a question about double lvl ridge. Will be framing using 2x12 with double 14"LVL ridge boards over a cathedral ceiling below. To gain the air flow from the soffit to the ridge would you guys let the rafters sit 3/4" higher than the ridge boards to allow air flow to the ridge vent? What have most of you being doing in this instance?
Ridge vent can be whatever you or your roofer prefers. Having a structural ridge has no bearing on what ridge vent product you use. Our engineer usually calls for minimum of one inch airspace whenever we use 2 ply LVL. I just go 1 1/2 because I have plenty of 2x4 blocks laying around.
I usually tack a 2x4 flat to the ridge and purlin the rafters to this. Don't forget to remove it when you sheath the roof.
That's what I do also. If it's a single 2x, I rip something down to 1" high. Anywhere a ridge vent is, this is done.
Thanks for your advice. do you let your sheathing overshoot the end of the rafters some on each side to take up some of the open space left by the lvl's 3 1/2" or how do you deal with that wide of a gap at the ridge?
KemoSabe
I do basically the same as Warren and Framerman. I usually use a 2x ripped to 1" to gauge the rafters above the beam. The sheathing is then cut back no more than 1" from the centerline of the roof, leaving no more than a 2" opening at the peak.
We have done the same thing with hips in some cases. Drop the hip 3/4" to 1" to allow airflow to the ridge. Some architects specify full venting of the hip, in which case the hip would get vented in the same manner as the ridge.:thumbsup:
The most important part of this detail after you allow for the air is make sure that over shot seathing is rugged enough to nail the ridge cap I often will make little 2x triangles to go on top of the lvl to make the seathing more ridged
Discussion Starter · #17 ·
Thanks Tim for the pics, I see what you did with the rafters that will work for me. Do you guys usually cut your seat cut on your rafters to sit completley on your top plate on a 2x6. I do but have read in code where heel cut should not be more than 1/4 of lumber depth which on 12/12 pitch would have you cut more than a 1/4 depth to get the 5 1/2" to sit completly on top plate of 2x6?
wannabe
What are you guys using for insulation? We're at r-38....I might be wrong, but we can't fit bat insulation in our cathedrals with an airspace so we've been using spray foam.
I'm not an advanced roof framer, but I was taught to cut rafters that notch over ply'ed LVL's so the long points meet at the actual ridge....I like the x-tra cut if we're using 20' DF 2x12's makes installing easier.
Edit: 800 :drink:
1 - 18 of 18 Posts
