Unfortunately yes.Mesh they still make that stuff?
Paper tape.......
I don't care for the mesh.....
JMPOV,
B,
Thanks Creter. My main point was everyone but that supplier sells 2''.
I never use paper with quickset.Paper tape.......I don't care for the mesh.....
How did you do your angles? Were there any? Mesh dont work in angles,, gotta picThanks Creter. My main point was everyone but that supplier sells 2''.
Just taped a job yesterday. Close to a couple hundred feet of tape,nine sticks of bead, twelve sheets. Done, sanding this morning.
Paper would have killed me. :wheelchair:
You guys that don't like mesh.............Grow up.
There are whole houses around here taped with nothing but mesh and Durabond 90. It's finished in one pass - no 2 or 3 coats. Pretty much all trowel work. I just did a ceiling repair, and I should have stuck with hot mud / mesh (which was how it was done originally) - the cooler, humid weather we're having right now is giving 2 day drying times.Mesh dont work in angles
Paper tape is equally rigid in all directions, mesh moves most on a diagonal, and will stretch some. Cracking can happen with eitherSure would like to see how you keep your angles square. Since mesh has no strength especially horizontally you are relying on the hot mud not to crack why not just eliminate the tape altogether.
That seems impossible to me.. Are all the ceilings and walls textured?There are whole houses around here taped with nothing but mesh and Durabond 90. It's finished in one pass - no 2 or 3 coats. Pretty much all trowel work. I just did a ceiling repair, and I should have stuck with hot mud / mesh (which was how it was done originally) - the cooler, humid weather we're having right now is giving 2 day drying times.
No texture on anything, flat ceilings and eggshell walls - just short of a class 5, because the walls aren't skimmed. Personally, I'm not that good at it. There used to be a lot of plasterers around here, and when things switched to drywall, people used and taught the techniques they were familiar with,That seems impossible to me.. Are all the ceilings and walls textured?
