1 - 9 of 9 Posts
I'm designing and building a U Shaped home office. Joining three tops together at a ninety degree angles. Can do this with removable Dominos and no glue? I want to be able to separate but only when I want it to.
Thank you in advance.
Maker of fine kindling
Use a few dominos for alignment and draw bolts to keep it tight. The ones in the link above are fine but there are many options in style.
Yes there are .Those aren't the ones I usually use either .Just a quick link I found for something similar.I usually don't use domionoes either but biscuits or a spline in a slot cut with a slotting cutter on the router.
1 - 9 of 9 Posts
