1 - 9 of 9 Posts
Men,
Has anyone ever used or seen a " 3/4"copper x 3/4" Male IPS tapped 90 degree elbow?? The tapping is for an air bleed vent on a hot water loop heating system. I've seen the common 3/4" tapped cooper elbow and a 3/4" copper x male IPS elbow but never one with the tapping.
Thanks
Men,
Thanks
Could you not knock one up with other fittings?
What are you talking about, tapped, tapping, these are not your common fitting words I ever heard for plumbing fitting.
Then there is knock one up, what is that all about?
By tapped he means female internal thread. As in Tap or Die thread. So that he can screw a air bleed valve into it. thats how im pictureing it. I dont do a lot of black iron work so this fitting is new to me. Dont sound like the kind of heating system vents i ever seen before. The type i normally use are AAV's.
By knock one up i mean if you can find 2 fittings that will do the same thing when joined together. I heard many different terms for things since moving from the UK so im used to some different jargon.
Found it. Elkart products carries it. It is not stocked in many supply houses since its an "i [email protected]!ed up on the roughing" fitting.
Thanks
Well, if you put a male thread with a female thread...:whistling
"cobble together"
"******* engineered" (yeah, I avoided the obvious one so as not to offend) :rolleyes:
1 - 9 of 9 Posts
