Does this duct meet code?
1682 Views 7 Replies 6 Participants Last post by  C. Ray Gill
I got emailed an article from JLC about how you can put a window in above a range hood in a kitchen. I was looking at the pictures. Isn't there a code issue with this duct? Isn't there supposed to be a minimum clearance from windows with outside ducting?
http://www.jlconline.com/cgi-bin/jl...e/82?c=0a87383f56bfc196130af1d876c11ee1#Light
1 - 8 of 8 Posts
fixed sash
I think the venting rules with distances to windows here are for fumes like plumbing vents and furnaces.
A hood is not req here unless you use gas.
That is a commercial gas range there...
I recall seeing this in JLC & going that's not right, but I haven't had the time to find the code that applies. I am pretty sure it is supposed to be 4 to 10 feet away from any opening. As the fixed sash window does not open - they are fine there - the question then becomes - how about the door.
Range hood ducts...Terminate outdoors (min 3ft. from opening or PL) IRC 1503.1 UMC 504.5
Ahh, I re-read it slowly... fixed window... :thumbsup:
Still I'd bet I could find one our inspectors who would fail it anyways. ;)
Only one? :blink:
NJ version of 2006 IRC says nothing about distance, so here I COULD have an operating window with no code issues. I would probably have customer issues after the first use.
http://www2.iccsafe.org/states/newjersey/NJ_Residential/Residential_Frameset.htm
Here in PDX, OR it's 3' away from a non-powered inlet (IE openable window) or 10' away from a powered inlet (IE makeup air fan.)
Here's the key to passing inspection in my jurisdicition:
"He shoehorns a fixed-sash window into the space above the range hood"
Note this right here /\ that little hyphonated word makes all the differance in the world!!! :thumbup: As in whether or not you pass inspection.:party:
C.Ray
PS Don't know why in the article they think this is a big deal, it's been going on around here since the 1900's- look at any plans for an arts and crafts (read Bungalow) house and chances are you'll see this window configuration- usually with leaded and/or stained glass.
1 - 8 of 8 Posts
