I am combining the dishwasher and garbage disposal circuit in my kitchen to free up a breaker for an additional SA branch circuit for the countertops. I am aware that to meet code that the appliances would need an disconnecting means which have been interpreted to include a plug and cord assembly on each connected to a shared outlet.
I am cutting this new outlet into the drywall using an old work box and wanted to "extend" the outlet to the surface of the back of the cabinet. I was under the impression that the proper way to do this was to flush mount the old work box to the drywall as with any standard plug and then use an extension ring to extend the outlet itself to the surface of the cabinet. However, the extension rings that I have found do not fit in an old work box and only seem to fit in new work boxes. What is the proper procedure to do what I am after? Do I simply pull the old work box an inch out of the drywall and mount it directly to the cabinet surface? That hardly seems correct, compliant, or safe. Do old work box extension rings exist and I just need to look better?
How do I handle this situation properly?
