1 - 20 of 22 Posts
Remodel
I've seen that. Usually it seems it was a new construction guy in an old house remodel. Or maybe just taking the easy way out, tough to say.
Reality is, there are some situations where a really good solution just doesn't exist.
· General Contractor
Using a smaller crown would looked a whole lot better. This way you would go right over the header continuously and run the legs up to it... Or take the end off and put a separate piece on top and and make a miter in the corner, this way it will hide the track and you can remove it if doors need to come out. Not to mention that crown is to big for that room anyway if the closet header only a few inches down from the ceiling plane. I assume this is a basement.
Thanks Greg for that info. My only other idea would be a 4x4 block . Like what they use around here when they can't cope a corner.
That just looks weird all around. The crown is too large for that room and the return (to my eye) is just wrong. My first instinct is no crown in that room, but if someone insisted on crown I think I'd go with something small enough to run over the top of the doorway. Speaking of the doorway, it seems like there would be a more elegant solution there as well.
I have to agree with Easy on the ceiling. Popcorn ceilings make me feel like I should be wearing capezios and skinny ties again.
I think that is a sliding glass door for a closet. If that was a real door that would be a real low cieling. Most likely the trim around it was already up and the crown installer went the easiest route.
I've never seen it before but it probably looks better like that then a regular 90 return.
Discussion Starter · #15 ·
It's a small condo, currently unoccupied, but still jammed with the belongings of the retired builder whose children have some decisions to make. I was in there briefly on some business for the homeowners association, and the crown caught my eye, because it was goofy but fairly carefully done.
The way someone else would have put up art, or a teenager would put up posters, the guy had personalized his space with crown moulding, matching oak wainscoting, and other not-quite-right details. The overall effect was very depressing.
Remodel
One other option that would look better (and I'm surprised nobody mentioned it) is to fade the molding into the wall / trim. Almost anything is better than leaving that at hard 90 degrees.
Yes, the crown is too big, but it really shows up here because it runs into the door trim. I don't see a decent way of fixing it other than defining a logical space for it to be ending on, and cut it back. Maybe do a little built-in in the previous stud bay, something... Paint schemes can help to make an early termination make sense, as well.
You're talking about a 45 deg return, right?
1 - 20 of 22 Posts
