WOW! Now that sounds like a reciepe for disaster!I used to build log homes and had a customer spray transmisson fluid on his logs. Looked pretty good actually, but I thought he was crazy as hell.
I'd love to meet with the adjuster on that claim.
"House burned down huh?"
"Yep"
"In ten minutes?"
"Yep"
"No survivors?"
"Nope."
"What did you paint it with?"
"Napalm."
Never heard of "latex"?All paints and stains are more flammable then diesel
Well, actually that's not true... Diesel fuel is combustible (it will ignite but relies on compressed heat as opposed to an open spark) but is not designated as "flammable". Xylene, Toluene & Acetone each have a lower flash point than diesel fuel - so from that perspective, it's actually safer than some of the more common paint solvents (mentioned above)...and that recipe has been around for decades. The problem is, diesel fuels are more oily than are most petroleum distillates, so you are introducing a foreign "resin" to the mix...primarily mineral oil which is non-drying, and has a very low viscosity. The mix is great for penetration and will not dry very quickly...and will take even longer to form a film - but it really doesn't pose much of a fire hazard other than the solvent fumes evaporate far slower than does the more common solvents used in conventional paints.All paints and stains are more flammable then diesel
...and by the way, this post we're responding to is from 2011Well, actually that's not true... Diesel fuel is combustible (it will ignite but relies on compressed heat as opposed to an open spark) but is not designated as "flammable". Xylene, Toluene & Acetone each have a lower flash point than diesel fuel - so from that perspective, it's actually safer than some of the more common paint solvents (mentioned above)...and that recipe has been around for decades. The problem is, diesel fuels are more oily than are most petroleum distillates, so you are introducing a foreign "resin" to the mix...primarily mineral oil which is non-drying, and has a very low viscosity. The mix is great for penetration and will not dry very quickly...and will take even longer to form a film - but it really doesn't pose much of a fire hazard other than the solvent fumes evaporate far slower than does the more common solvents used in conventional paints.
