But the cordless compressor instead. We probably use ours more than we use a corded compressor anymore.This would definitely be a semi-impulse buy. I do have a job tomorrow that would be convenient to not bring the compressor and hoses and so it caught my eye.
I’m on the fence boys.
That’s not a bad idea. I’ll look into that option. Thanks WarrenBut the cordless compressor instead. We probably use ours more than we use a corded compressor anymore.
We carry around a 20 ft hose with ours. It can do very light framing, but will not keep up with any framing larger than punch out. We framed a basement once and blew up the first one.That’s not a bad idea. I’ll look into that option. Thanks Warren
decided to hold off and think about the battery compressor versus battery framer debate. Will think hard about which one will benefit me most. Thanks for the insight.We carry around a 20 ft hose with ours. It can do very light framing, but will not keep up with any framing larger than punch out. We framed a basement once and blew up the first one.
Now you’re talking! I didn’t even know they made an adaptor like that. I’ll look into that. Been working good for you huhI forgot to mention, I bought 2 adapters for $15 on Amazon. That way we can use the DeWalt batteries in the Milwaukee.
If and when I buy the Dewalt I’ll report back. I backed off of the impulse buy today. I will shop around for a deal.Hope you'll let us know how the weight affects you using it. I looked at the MW a year ago -- too heavy. Us older guys are looking to shed tool weight.
Picked up the Paslode display model and it was the lightest weight at around 7lbs and I could feel the difference. It felt the best in my hand too I’ll admit. Buying gas cartridges just makes me lean away from Paslode.Some of the boys strayed to Milwaukees but have all come back around to paslode, king of cordless nailers. We've had a couple dewalts and they couldn't hold up to relatively light use, mostly setting trusses not sheathing. We set and sheet with paslodes on steeper roofs. Just need some maintenance/cleaning but you can get away with 6-10k nails between cleanings.
Sent from my Pixel 4a using Tapatalk
