You could probably leave the top of the beam a bit lower than the joists and put composite shims on top of the beam at the joist locations to keep the decking level. Wrap the beam and fascia top with Vycor to prevent water from getting between the layers.
It looks like 2x decking so you could probably just rip a single piece of 2x PT so that it extends from the first decking edge that doesn't fall over the beam to whatever the fascia overhang is. With one piece you won't have anywhere for water and crud to flow through to the beam surface. Cut a 1/8" kerf in the wide piece of PT to make it look like multiple decking boards.
That's my quick and dirty recommendation which is what I assumed you were looking for.
