I was on a job today and saw the electrician installing a post lamp light. He was using direct burial UF wire from the house to post lamp. All he did was stick his shovel in 4-6 inches and lift the ground up and slip the wire in the hole and then take the shovel out and stomp the ground back down. I'm not an electrician so don't have a clue but 4-6 inches seems like it should be buried deeper so someone doesn't cut it planting flowers. What is the code for how deep UF wires need to be buried to post lamps?
Also, should a post lamp be set in concrete or just in dirt? I went out after he left and it was really loose, as in I could wiggle it very easy. He just piled the dirt back in around it. Just seemed like an all around hack install and I've never even put one in. Just wondering if he was a hack or if what he did is alright?
