I'm building a commercial laundromat in NYC and next to the washer platforms we have knee walls going in to close of the sides. On the backside we decided to use a Densshield as a tilebacker being that they get some moisture we thought it would be a good idea to ensure that it is waterproof. This is my first time using the product and I see many of you are familiar with it, so I had a few questions.
1. What product should I be using to seal all the joints between sheets? I believe silicone is correct but is there a specific brand or type?
2. How should I seal up and penetrations made if they are an inch of so larger in diameter than the conduit passing through?
3. Lastly, I noticed a few sheets had some of the gray waterproof layer is peeled along some of the edges. I am trying to avoid using those sections as much as possible but is there a way to seal it off or should I just grab another sheet from my supplier? Realistically I should just have them replace it but I can't wait on them to deliver new sheets.
Thanks
