1 - 5 of 5 Posts
Retired Contractor
I'm putting in a dedicated Dehumidifier Drain in the basement and could not find this answer. The drain is in the wall, not the floor....that would have been easy.
Since it's going to be the lowest "fixture" on the line, I've put in a backflow preventer and yes, its a vented line. I'm using a 2" line downstream of the trap and 1.5" for the trap and vent. (Did that in case its ever upgraded to a kitchen)
My question is this...to avoid a Running Trap how high does the inlet need to be? All I can find is Max Height of the fixture above the trap weir, but nothing that tells me the Minimum Height.
The Grand Wazoo
It's going to vary by code, here it would be 4X the pipe size, so 8"
1 - 5 of 5 Posts
