1 - 15 of 15 Posts
Contractor
currently there is 2x6 boards on 24" spaced joists. I'm guessing 5/4 composite wouldn't work b/c of the span-can anyone confirm? if not, does anyone make a composite rated at 24" joist spacing?
Yeah, I don't think that will work with 5/4. You could go with Correct Deck or Cross Timbers, that might work. Maybe the TimberTech T&G would work, seemed pretty stiff last time I used it.
Dont know for sure, check with the manufactureres websites, any composite that can be run at a 45 with 16" centers might handle the 24". Another thought would be to sell them on droping in new joists inbetween, that would make a nice solid deck. G
Custom cabinetry
Correct Deck CX will span 24" O.C. and we have installed (per homeowners request) at 45 degree angle @ 16" O.C. and it was fine. So its about the same as 24" o.c.
Crosstimbers is rated to span 24" O.C. but it sags in heat on 16" O.C. so that would be a dumb choice.
KemoSabe
I used Timbertech T&G about 12 years ago on a front porch deck. It was rated to span 2' centers if memory serves me.:thumbsup: I believe it is the Floorizon line.
1 - 15 of 15 Posts
