What difference does it make what was there if your going to replace them anyways? Yo can make your own treads from 2x12's or from 5/4. It's your rise you should be worried about.
i was baffled by the 2x10's at the bottom and then the 2x12's for the top 2 treads...What difference does it make what was there if your going to replace them anyways? Yo can make your own treads from 2x12's or from 5/4. It's your rise you should be worried about.
thats what i figured. the 2x's look like crap to begin with. she wants to re-use them though which sucks. whatever the customer wants though.Hackery is going on, GMOD
That's where you are wrong. You are the professional and YOU tell the HO how it's done properly and that's how you do it.thats what i figured. the 2x's look like crap to begin with. she wants to re-use them though which sucks. whatever the customer wants though.
Otherwise you just propagate the hackery.
If you DO hack work, you are a hack.
point taken, but if she wants it like that she wants it like that. the decking is 2x6, and ideally i'd like to use 2x6 to match it but she doesnt want toThat's where you are wrong. You are the professional and YOU tell the HO how it's done properly and that's how you do it.
time restraints. i wasnt going to fully commit to it because i really dont know when i'll be able to do them, and i dont want to be harassed about it. i'll probably end up doing them with my friend either way.I'm trying to figure this out, what's the overhang on the risers? What was the hieght of the risers? Why did you pass it off to a friend?Seems like a good job for one person.
hey i'm not arguin with ya, i'd much rather that. but i did pass it on to my friend, so its between him and her now. if i am able to help him with it then i will.I don't get why you would even consider using cobbled together pieces?
Whats (2)8' 2x12's cost?
Personally I use rows of 2x6 radius edge For 11" treads. (I hate 5/4)
4 rises would cost like $30
If a homeowner can't afford that, run away
So if a HO tells an electrician to use 14ga wire where 10ga is neededpoint taken, but if she wants it like that she wants it like that. the decking is 2x6, and ideally i'd like to use 2x6 to match it but she doesnt want to![]()
