With the drill set to high speed, install the Cortex screw into the deck, allowing the screw
to rotate freely on the deck surface for a few seconds before threading into the deck.
Drive each screw in one continuous motion. Do not slow or stop until the setting tool has
disengaged automatically from the screw.
· Install two screws per joist, making sure they are perpendicular to deck boards. If
necessary sister a block of wood to the joist so the screw can be driven perpendicular.
· Place the Cortex plug into the cored-out hole and gently tap until it is flush with the deck
surface.
· Periodically change a worn driver bit for a fresh bit at least every 125 screws.
· Pre drilling is required when installing screws near the ends of the board. Using a 5/32”
or 3/16” bit, pre drill only the deck material (not the framing) prior to installing the screw.
· Pre drilling is usually necessary when installing decking over existing (old) framing, for
boards measuring over 1 ¼” in thickness, or in cold weather installations (below 40
degrees). Use a 1/8” or 9/64” drill bit to drill through the deck board and into the joist the
full length of the bit.
· If damage occurs to the screw while being driven, do not continue to drive the screw in.
Back it out and install a new screw.
· If you experience a consistent problem installing the screws after applying the above
recommendations, please contact FastenMaster before continuing your project. In most
cases we can determine the cause and solve the issue over the phone.
Special Instructions for Trex Transcend Installation
· For best results use a drill with a ½” chuck either corded or battery powered of at
least 18 volts. Use the drill on high speed.
· If difficultly is experienced installing the screw predrill through the deck board with a
5/32” drill bit. Do not predrill into the joist.
Special Instructions for TimberTech Earthwood Evolutions Installation
· Predrill through the deck board with a 5/32” drill bit. Do not predrill into the joist.
Removing a Plug and Screw
· Using a trim screw (#7 or smaller), center the point in the plug you are looking to
remove. Slowly install the screw until the point passes through the plug and “bottoms
out” on the screw head below. Remove the plug using the screw as a handle.
· With a standard #1 square drive bit (not the setting tool), carefully engage the recess of
the embedded Cortex screw. On slow speed, centering your weight over the drill,
reverse the screw out of the deck.
Removing a Damaged Screw
· If the head is above the deck surface, use one of the following methods:
o Remove the driver bit from your drill and open the chuck wide enough to capture
the head of the screw. Tighten the chuck firmly around the head and set the drill
in reverse and on low speed. Slowly draw the fastener out of the deck.
o If you prefer to use Vise-Grips, grasp the screw head but be sure to protect the
deck surface from tool marks by providing enough clearance between the tool
and the deck’s surface.
· If the head is at or slightly below the deck surface, use these methods in order:
o Use an impact driver with a new standard #1 square drive. Set the tool on
reverse, align
