1 - 20 of 24 Posts
Renaissance Man
I used to post here all the time, primarily masonry, but also the carpentry sub sections, etc...
Figured I'd jump back in and see if anyone remembers me...
This one is only 11 years old.
Hand Pneumatic tool Tool Finger Power tool
Window Wood Urban design Floor Composite material
Hand tool Drill Handheld power drill Wood Tool
Tool Wood Metalworking hand tool Font Metal
Outdoor bench Infrastructure Window Road surface Urban design
Wood Road surface Asphalt Building material Composite material
Wood Building material Rectangle Composite material Lumber
Road surface Asphalt Wood Slope Line
Window Wood Building Road surface Porch
Renaissance Man
Good to see you back.
Treated lumber ain’t what it use to be. My guess that is not ground contact rated as it should be that close to the ground.
So you not doing masonry now?
Yea, still do it all...
Renaissance Man
Discussion Starter · #10 ·
It's funny, I thought so as well. It's Madison lumber, ground contact, Copper Azole...I found a few tags. A lot of flat blocking for the pic frame, probably didn't treat any cuts, no flashing, stair stringers we're mush.
Yep, I remember you. In fact every once in a while I think, "Now, what would Superseal do in this situation.
I still use my big giant to pull posts. Best simple idea seen ever.
Glad you're back. Stay awile.
welcome back, but no matter where you live pressure treated lumber sucks lately!
This was one of my last projects!
Water Wood Plant Grass Tree
Reactions: superseal
Did you replace every joist? Some look fresh while some look they still have water stains, although they look cleaned up a bit. It was my understanding that new and existing joists shouldn't be mixed because the new joists will "shrink" as it dries (assuming it's PT) and you may wind up with "wavy" decking. Looks good though. I don't do many repair jobs.
Renaissance Man
Discussion Starter · #17 ·
Didn't replace every joist, the water content even with all new lumber varies a bit so you're never really safe. I get what your saying though. We did leave them a little proud when we planed everything out.
1 - 20 of 24 Posts
